Low Coolant Light
Old Jul 20, 2010 | 02:42 PM
02 CamaroSS's Avatar
Low Coolant Light
I have an 02 Cameron AS and I have a low coolant light on my dash, but it doesn't light up when u first turn the key on and I can't find the sensor in the rad. It's definitely not there. I have looked on both sides. I guess they used a gauge cluster from a year that had the sensor? Thanks.
Also, on the passenger side opposite where the secondary air pump is there is a vacuum canister. It is about 6"-7" long. What is its purpose?
Old Jul 20, 2010 | 03:06 PM
2001NBMZ28's Avatar
Low coolant sensors were finally taken off the F-body in '00 I believe. I know my car doesn't have one.
Old Jul 20, 2010 | 08:22 PM
Ok thats good to know. Do u happen to know what the component is in the passenger splash area under the overflow bottle? It's about 6-7" long and has a vacuum line running to it. I unplugged the line and I heard it hiss as air escaped.
Old Jul 20, 2010 | 08:27 PM
dabeastz28's Avatar
def think its located on drivers side head might actually be the gauge sensor tho or below steam pipe on rad good luck
Old Jul 20, 2010 | 08:49 PM
Are u saying the low coolant sensor is on the drivers side head?
Old Jul 21, 2010 | 08:50 AM
2001NBMZ28's Avatar
The sensor in the head by #1 is the ECT sensor, low coolant sensors were in the radiator a few inches below the fill cap. The other thing you disconnected was probably the vacuum resevoir/storage tank.
Old Jul 21, 2010 | 11:30 AM
The vacuum reservoir is for the HVAC controls. Sounds like it hasn't changed much. This is Shoebox's photo from a 95:
http://shbox.com/1/vacuum_tank.jpg
Old Jul 22, 2010 | 10:22 AM
Yeah that's definitely it. I suppose thats so that various doors can open and close to direct heat/ac?
Old Jul 22, 2010 | 11:04 AM
Here's what it controls, courtesy of Shoebox:
http://shbox.com/1/hvac_vacuum.jpg
Old Jul 22, 2010 | 01:28 PM
That's a good schematic to have. Thanks for the post.
calaban
May 18, 2020 06:43 PM
silvermansteve
Mar 4, 2015 05:02 PM
MattFick
Feb 15, 2015 10:16 PM
Jan 23, 2015 01:13 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
