Lots of Questions...
Old May 12, 2006 | 12:45 AM
Gun5's Avatar
Well hmm?
I need to get a set of 20 lug nuts for my firebird (locking/regular w/e) just the cheapest I can get really I'm missing 1-2 from every wheel just gonna get a whole matching set.. anyone know where I can get one??
I'm going to order a new valve cover breather (LT1) since mine doesnt evne have one should I get one with a vacuum line hole or not? all the ones listed on sites for LT1's dont have them but i know a line runs there
Rear Seat delete... whats the best place to get a coverup kit for this?? i found http://www.speedspecialty.com/store/...duct=rrseatcvr but iv never heard how good theres are and such
I wanted to divide up my new spark plugs im putting on so they will look better and wont get burned up (MSD wires).. I'v looked on thunderracing.com they got kits for the valve cover looms ($49) but i found one on ebay http://cgi.ebay.com/ebaymotors/ws/eB...MakeTrack=true was wondering if anyones bought it before??
Old May 12, 2006 | 06:29 AM
teke184's Avatar
Re: Lots of Questions...
www.ebay.com
just search for camaro lugnuts
they have full sets, chrome, with locks and even chrome covers for the stems....something like $20 i think
been looking at them myself
Old May 12, 2006 | 08:13 AM
Gun5's Avatar
Originally Posted by teke184
www.ebay.com
ya gonna pick a set off there.. found a nice one for $20
bump
Old May 12, 2006 | 08:30 AM
ucnu112's Avatar
I got a new set of 4 locking lugnuts from my local Big O tires for $12. It was going to be $10 for just 1 locking lugnut (to match the one I lost).
I've got the ones on the top right and love them. Very easy to use and work well.
Old May 12, 2006 | 09:20 AM
LT1's don't have a breather because they don't need one. It a "closed" system, utilizing cross-flow air that has passed through the MAF and been measured, since it ends up in the combustion process. All you need is a plastic elbow that connects to the vent line from the throttle body, and plugs into the grommet in the valve cover.
Old May 12, 2006 | 04:36 PM
Gun5's Avatar
so just slap a filter on it and be done with it
Old May 13, 2006 | 08:08 AM
Do you mean adding the Deutsch inline filter that replaces the plastic elbow? Using that and attaching the line from the throttle body keeps the system "closed". If you mean adding a "breather" filter, you will open up the system, and you will need to block off the connection on the TB that the hose used to connect to. Then you will have an "open" system.... technically a minor vacuum leak, but nothing the long term fuel corrections can't correct for.
Old May 13, 2006 | 04:48 PM
Gun5's Avatar
nope talking about this filter one that goes in the hole on my valve cover on the passenger side when I look on my vacuum diagram above the raid it shows a tube going back there I assume it hooks into the filter or am I dead wrong?
Old May 14, 2006 | 09:48 AM
You are dead wrong... you don't understand how the PCV system works.
Its a CLOSED system. And that's NOT a vacuum line that runs from the TB to the valve cover. The only outside air that gets into the PCV system enters through the main air filter, passes through the MAF sensor, goes through a hole in the throttle body in front of the blades, under the top cover and out the side of the TB, into the hose to the passenger side valve cover. The line from the TB is not a vacuum line, its an air supply line. That air gets pulled through the crankcase into the lifter valley, out the bottom of the intake manifold through a passage to the PCV valve, and through the PCV valve, pulled by vacuum from the intake manifold.
If you add the breather style filter you pictured, you don't need the line from the TB to the valve cover (or to the breather filter) because you've now created an OPEN system, and the air will be pulled in through the "breather". The only time anything will come out of the breather will be if you have excessive blowby on the rings and the PCV can't handle the volume, or your PCV valve is plugged up.
There is no practical reason to add the "breather" except for looks. The stock PCV system works well on a healthy engine. Mine works fine on an 800HP nitrous motor.
Old May 14, 2006 | 12:45 PM
Gun5's Avatar
got ya now, damn im stupid so I should just block this hole in the valve cover? because it is open as it stands now
Old May 15, 2006 | 12:15 AM
No, you can't block the hole in the valve cover, because then there would be no fresh air to be pulled through the crankcase to remove the blowby gasses. Either leave the stock line in place and the plastic elbow in the hole, or put a breather in the hole and remove the line to the TB and put a vacuum cap on the connection at the TB.
Old May 15, 2006 | 12:43 AM
Gun5's Avatar
ya theres no elbow or anythingi n the hole its just a hole
Old May 15, 2006 | 04:48 AM
jutt26's Avatar
Gun5...Ive got a set of standard lugs if you want them...give me about 5 more hours to get off work and Ill make sure I have all 20. (around 10-11am EDT)
2QUIK6
Sep 17, 2016 02:31 PM
MDZ28
Sep 7, 2015 09:16 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
Pwilson59
Sep 3, 2015 08:47 PM
