Loose door panel
Old Feb 3, 2005 | 12:25 AM
csucguy18's Avatar
Loose door panel
My drivers side outside door panel is slowely comming apart from the door itself. Whats the right type of glue(where can i get it?) i need to set that baby back in place! Thanks!
Old Feb 3, 2005 | 11:46 AM
MarineReconZ28's Avatar
Re: Loose door panel
I have the same problem. I don't know what the right stuff is, but if you find out let me know! I've used about four different types of adhesive and none of them have held up. It could be that it was cold outside when I tried to put it on (low 40's) so it might not have had enough time to cure. One type of epoxy adhesive lasted about 3 days before I slammed the door and it seperated again, but other than that I have left the clamps on the door all day with the door open and then closed it before I went to bed, and when I come out in the morning it has seperated on its own. So I don't know. I'm about to go look for a door at a junkyard.
Good luck with yours. PM me if you find anything that works for ya!
Old Feb 3, 2005 | 09:54 PM
csucguy18's Avatar
Im about to go to an autobody shop soon, see if they can recommend anything. If i find out ill be sure to let you know.
2QUIK6
Sep 17, 2016 02:31 PM
Henson071
Sep 18, 2015 04:01 PM
Wart Hog
Sep 8, 2015 05:53 AM
michael42869
Parts Wanted
Aug 3, 2015 10:22 AM
ducttape1975
Jul 10, 2015 06:29 PM
