little weird gauge prob.
Old Feb 20, 2008 | 01:10 PM
Bluovlh8er's Avatar
so like for the last month my fuel gauge has been weird.
from almost empty, ill put like 5 dollars in and it goes all the way to full. it drops quick though (because only $5 worth of gas)... also theres times when i start it and it will read 1/2 tank... then ill drive for a little bit and it will jump from 1/4 to 3/4 ???
98 v6 3.8 camaro
Old Feb 20, 2008 | 01:22 PM
ss.slp.ls1's Avatar
The gauge is highly inaccurate from the factory. Just gotta get used to it.
http://shbox.com/1/4th_gen_tech2.html#fuel_gauge
Old Feb 20, 2008 | 01:48 PM
PSU 98's Avatar
Lots of people have problems with the fuel gauge over time. Mine worked well up until a few months ago, then it started jumping around anywhere between 1/4 and 3/4 tank. Anything over or under that and it still works.
Old Feb 20, 2008 | 04:35 PM
While the 4th Gen fuel gauge tends to be inaccurate, I don't don't think that extends to the situation he is describing - its almost "empty", he puts in LESS THAN 2 GALLONS - and it goes to "full". That's well beyond "normal", particularly since it only started happening recently.
Old Feb 20, 2008 | 04:48 PM
Bluovlh8er's Avatar
so whats the prob??? fuel pump?
i forgot i let it run out of gas last week... i know its bad but i couldnt help it. i was in bfe!!!
Old Feb 20, 2008 | 04:58 PM
The fuel pump doesn't affect the gauge. There are three possibilities.... 1) the sender is faulty. Sender is in the tank, riveted to the fuel pump support assembly. 2) the guage is faulty, with one of the two magnetic coils in the gauge burned out, or 3) the wiring is loose or corroded.
I'd guess its #1. The float dropping to the very bottom of its range due to the tank being empty may have damaged the rheostat coils or loosened some dirt that is causing intermittent contact.
Old Feb 23, 2008 | 03:39 AM
bigboybowtie's Avatar
okay, im 90% sure that it is either corosion on the level sensor points, or worn out teeth, the corosion usually occurs when you run car low on gas a lot and the worn out points just happen over time, and its very common on 3rd gen camaros with tbi 5.0 liters, series II 3.8, and any chevy vortec
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
drt
Sep 27, 2015 04:39 PM
RX Speed Works
Sep 11, 2015 03:31 PM
jackpawt883
Sep 10, 2015 08:53 PM
