Lights dont turn on when you open drivers door?
Old Jan 4, 2008 | 08:39 PM
sabedra211's Avatar
My lights inside my car dont turn on when i open the drivers door, but when i open my passanger door the lights turn on.. Also when i have the keys out my stereo still works until you open a door. but when i open the drivers side door the stereo still plays. All the buttons on the door works. Has anyone had this problem before???
Old Jan 4, 2008 | 08:58 PM
MasterEvilAce's Avatar
Definitely sounds like your door switch is broken. Given that the passenger works like normal, everything seems to function fine.
Open your driver door up, look around the hinge area. You should see a 'button' of sorts that gets pushed in when the door is closed, and is spring-loaded so it SHOULD pop out when the door opens.
That is probably broken, or there's a loose connection there. You can open the passenger door and push the switch there and watch the lights flicker. Do it on the driver side, and nothing will happen.
squarehead
Jan 15, 2015 07:02 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
97z28k&N
Jan 9, 2015 04:58 AM
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
Fbodfather
25
Jun 21, 2002 04:12 PM
