Lifting Jack size?
Old May 13, 2007 | 12:22 PM
Mister Will's Avatar
Lifting Jack size?
If I want to lift up the front end of my Z28, how big of a jack/lift do I need. Basically I am looking to get under my car to change out the manifold O2 sensors. I intend to purchase a hydraulic lift. Lift the front end high enough to put floor jacks under it and remove the sensors from underneath.
Yes this sounds like a simple question, which is exactly why it would be so easy to screw up. But there are people on this board who have a lot more experience than I do with working on these cars, both personnal and professional. I want to hear from people who make sure they don't drop their cars.
I'd also like to know about lifting points too while I'm here.
But I can do a search later.
Old May 13, 2007 | 09:00 PM
Dave '97 Z28 M6's Avatar
I have a 2 ton hydraulic floor jack, which easily lifts up 1 corner of the car, but becomes a PITA to lift half the car up - it's just a bit too small. I also have 4 ton bottle jacks that easily lift up the entire front or rear of the car.
Look here for lift points:
http://www.installuniversity.com/ins...ift_points.htm
Old May 14, 2007 | 10:39 AM
Z28SORR's Avatar
Your car weighs between 3500 and 4000 lbs. Or just under 2 tons.
So a minimum size, for safety, would be a 3 ton jack and stands.
Most common would be 5 ton, as they are not much more expensive and give you a little added safety factor.
Also, DO NOT, buy the three leg jack stands, get the four leg style.
Victor Lamb
Aug 26, 2017 02:52 PM
HectorM52
Jul 30, 2017 11:46 AM
1775.Z28
Jan 11, 2015 10:51 AM
squarehead
Nov 21, 2014 08:02 PM
JasonD
Aug 16, 2002 11:52 AM
