Length of Rod? How to measure
Old Nov 21, 2004 | 05:58 PM
Red_94Formula's Avatar
I got some Luntai pro comp rods. Dont know what if they are 5.7, 5.85 or 6.00. At what points do I measure the rod to find out?
Old Nov 21, 2004 | 11:00 PM
Re: Length of Rod? How to measure
Could the length of the throw be anything other than center to center?
Old Nov 25, 2004 | 09:25 AM
Bud M's Avatar
Why measure rod length? You're just going to lie about it anyway
Old Nov 25, 2004 | 09:56 AM
trackbird's Avatar
It is center to center. The easiest way is to use a caliper to measure from the top of the crank bearing "hole" to the bottom of the pin hole (basically just measuring the "shaft" and none of the "hole" at first). Write this number down, then measure the pin hole and the crank hole with the caliper, divide each of those numbers by 2 and add the results to the first measurement. That is about the most accurate way to do it.
Old Nov 25, 2004 | 01:38 PM
BirchMan98z's Avatar
subtle.
13qtr
Oct 28, 2016 08:11 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
heus
Sep 8, 2015 12:01 PM
POLOVETTE 94
Aug 21, 2015 07:11 PM
