keyless entry question
Old 02-20-2006, 02:39 PM
LqMth's Avatar
The keyless entry on my '93 (ugly square 2-button transmitter) hasn't worked since I got it. The d/s and p/s switches inside don't work either. The switches have a common power and ground. The fuse is good. Would the keyless entry not working cause the switches to not work also? I noticed in the wiring diagram that the keyless entry reciever is in-between the switches and lock actuators. Can anyone tell me where the ground would be or what the chances of the reciever being bad are? Any help is great because my manual is about 5 states away. I got the basic diagram on shoebox's site. Thanks Nathan
LqMth is offline
Old 02-20-2006, 08:34 PM
LqMth's Avatar
Re: keyless entry question
TTT for the evening crew.
LqMth is offline
Old 02-20-2006, 10:14 PM
6SpdLT1Z's Avatar
Not real sure, have you tried grounding your keyless entry per how shbox's website describes? That may atleast fix your keyless entry. If not they're is probably something not working. Lock Acutaer (sp) or something.
6SpdLT1Z is offline
Old 02-21-2006, 01:13 PM
LqMth's Avatar
I didnt see the part about grounding the keyless entry. I'll look that up. I doubt both of the actuators are bad. Nathan
LqMth is offline
dluna333
15
03-13-2015 12:30 PM
jasonduaine
03-07-2015 09:44 AM
95z_28_camaro_4_Ivan
12-19-2014 08:48 PM
Hurin
12-13-2014 07:38 PM
DirtyDan
09-28-2009 10:27 AM
Quick Reply: keyless entry question
