Just won a 1994 Firebird Formula...
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
so what do u guys think? how much power should all that **** really make?
The only thing i'm really concerned about is ->> "Also, I did want to add, the speedometer is off. It has only been off since the cr has been put back together within the last 1,000 miles. This is due to the car originally having 2.73:1 gears, and it now having 3.42's, as well as possibly a bad vehicle speed sensor($24 part that hooks into the transmission). The needle just keeps climbing as you accelerate, and is farther off the faster you go."
what do you guys think...
Re: Just won a 1994 Firebird Formula...
Originally Posted by Z95m6
The car should make 400rwhp if its running right. It has ported heads and a CC306 cam.
I don't think the guys had it programmed yet they dumped all the money into it but ran out so i gotta send the ECM off I imagine.. or i might just get a hyper tech programmer
no hypercrap do a mail order or dynotune
Originally Posted by ZRedLT1
Get a PCM4LessTune or MadZ28 Tune and you could see 375-400 RWHP
Mid-High 11's?
Mid-High 11's?
getting the car tuned locally (guy named moe if you live in texas and got a f-body u know of him problaby he does tons of Z06's camaro's and fbirds) for $300
• will ride in car see before/after with tuning to see if the tunes need to be tweaked
• desired idle speed
• desired shift points
• rev limiter
• Speedometer recalibration for gear swaps
• Speed limiter removal
• change fan activation temps
• change/delete torque management
• remove Skip shift
• remove SES lights (off-road use)
• fuel flow
• any future upgrades = free tune
i think this is a pretty fair price for the above..
also this car is going to change alot in terms of apperance... its being mated with the front bumper/hood/ back hatch(cuz it has the blue stripe/flames on it to) and all the ground effects from this brand new painted body im picking up from a friend (also maybe a few more hp w/ ram air when its all set up)
formula79
Jul 12, 2002 01:58 AM
