Jethot LTs broke or not?
Ill make this short. I have Jethot LTs and Eibach Pro-kit. I hit a bump/dip in the road very hard on my passenger side header. The two bottom tubes are bent in or crimped like 1/4 inch or so. What are my options other than replacement Can i buy only one header from Jethot? Is there a way i can get them bent back? Also how badly would this affect performance. Thanks in advance.
Re: Jethot LTs broke or not?
you might be able to put a pry bar in the collector and push the dents out. I did this with a set of used long tubes i bought for my Mach 1. I had to heat the tubes though in the area to get them to bend out, i did this before i had them coated though. If not body shops have special tabs they can spot weld on and use a slide hammer to pull dents out of cars. I'm sure they could do it to your header. Once again the coating will be ruined.
