Installing a Fuel Pressure Gauge
Old Mar 12, 2011 | 08:37 PM
my1994z28's Avatar
In the begining stage of installing a autometer fuel pressure gauge in my 94 z28..Is the schrader valve a safe place to install it?Anyone know the part # of the fitting I need to make this work?
Old Mar 13, 2011 | 04:08 AM
97WS6SCharged's Avatar
Re: Installing a Fuel Pressure Gauge
The schrader valve will work fine, just remove the actual valve assembly. I would recommend mounting the sender to the body and connecting it to the valve with a piece of braided fuel line though. The gauge instructions should have the adapter PN.
Old Mar 13, 2011 | 09:17 AM
my1994z28's Avatar
Yeah,I thought it would have came with the part# as well but,no luck..I even called Jegs tech support and no help there either..It came with one adapter and its for a Ford..I am going to run to the hardware store to see what I can come up with.Thanks
Old Mar 13, 2011 | 09:23 AM
Are you installing a mechanical gauge, or the pressure sending unit for an electronic gauge?
Get an NOS #17585 -4AN 90-deg swivel fitting. Remove the core fro the Schrader valve. Screw the NOS fitting on, aiming in the correct direction. Do NOT over-tighten it, the Schrader connection is only swaged on the line, and will snap right off.
Get a short -4AN braided SS hose, with a -4AN female on one end, and 1/8" NPT male on the other. Use a 1/8" NPT coupling to connect the hose to the gauge.
Hopefully, you are installing this under the hood if its a mechanical gauge. It can NOT and should NOT be mounted in the passenger compartment.
Old Mar 13, 2011 | 01:40 PM
my1994z28's Avatar
Installing the sending unit for the electronic gauge..
Old Apr 17, 2012 | 02:27 PM
am_muscl's Avatar
i know this is a really old thread but I found it by a google search.
I recently bought some cyberdyne gauges (trans temp, fuel pressure, oil temp, oil pressure) and the oil pressure and fuel pressure sending units look identical.
Cyberdyne Gauges SENSS4E - Cyberdyne Gauges Gauge Sending Units - Overview - SummitRacing.com
I already removed the internals of the schraeder valve and now I'm stuck with what to do.
I called summit and they said "according to autometer, I have to buy an adapter with a hard line" and that costs over $40 that seems a little crazy to me, but idk
Old Apr 17, 2012 | 04:20 PM
What specific vehicle are you installing the gauge in? Is this a carb application? The fuel pressure sending unit is only 15psi, so its not suitable for a high pressure fuel injection application. From the "application" tab in the link you posted:
Universal Yes
Gauge Type (application) Fuel pressure
Maximum Gauge Face Reading 15 psi
Generally, it's a good idea to add a "Signature" with basic info about your car - year, model, engine, trans, and any major mods. The Signature is automatically appended to all your posts. That way people will have enough into to help you.
DirtyDaveW
Dec 1, 2016 05:37 PM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
Burn_Out
Aug 18, 2002 08:49 AM
