install question
Old Sep 26, 2005 | 09:48 AM
1crazylt1's Avatar
install question
how do u remove/install front wheel studs?? on a 94 z
Old Sep 26, 2005 | 11:49 AM
AW/whiteZ-28's Avatar
Re: install question
Take the caliper, rotor, caliper bracket, and anything else in the way of the wheel hub bolts. Then unbolt the wheel hub, after you have them off the car you should be able to get them off.
That's all there should be to it.
Old Sep 26, 2005 | 11:52 AM
Z95m6's Avatar
A big hammer.
Old Sep 26, 2005 | 11:55 AM
Originally Posted by Z95m6
A big hammer.
Oops forgot the most important/fun part!
Old Sep 26, 2005 | 12:25 PM
If you want to press them out, and back in (the best way), you need to remove the complete hub cartridge as noted above. But I've had success simply hammering the studs out, with the hub in place. The argument against doing it this way is that you could damage the bearing. So far, mine doesn't show any signs of damage.
To put them back in, put the stud in the hole, put a washer with some anti-sieze on the stud, then screw the flat side of on old lug nut against the washer and pull the bolt in with an air impact gun.
Old Sep 26, 2005 | 05:26 PM
Closing the thread, because you've got the same post scattered all over multiple forums.
Pick one forum..... hopefully the correct one.... and post ONCE.
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
nautilus
Aug 22, 2002 11:49 PM
Chrisdude
Jul 24, 2002 02:25 PM
Brent94Z
Mar 21, 2002 04:44 PM
