Inspection question again
Old Jan 21, 2006 | 05:57 PM
Demon's Camaro's Avatar
If I install my pacesetter LT's, a high flow cat and a hooker cat back will that pass visual inspection in NY? Its only a visual inspection on 95 and older. Will the relocation of the cat make it fail?
I have a 94z28.
Old Jan 21, 2006 | 06:00 PM
2000GTP's Avatar
Re: Inspection question again
I have a 94z28.
Its kind of a hit or miss. If the inspector knows what he is looking for then yes you can technically fail if the cat. is relocated. Also, if you have the cat. placed at the end of the y-pipe, then it may not be nearly as efficient either and it may have trouble with the sniffer test as well.
Old Jan 22, 2006 | 02:00 AM
Kataklysm's Avatar
Yes it could cause you to fail but I think most inspection stations don't pay attention to where the cat is. You would be better off running dual cats as well.
Richardan15
May 30, 2015 08:36 AM
lt1matt
Mar 21, 2015 07:35 PM
dluna333
15
Mar 13, 2015 12:30 PM
Bob_Ricco
Jan 27, 2015 11:44 AM
Lederman1976
Nov 30, 2014 05:21 AM
