Ignition switch problem?
Old Feb 5, 2005 | 08:48 AM
SS Joe's Avatar
After replacing the belt yesterday (don't see how it could be related, but just mentioning it) on my 97 SS, I tried to start it and the switch felt a little weird. The car won't start (or even turn over), and nothing happens when the switch is in the on position. It almost acts like a dead battery, but the lights work and the battery tests ok. The car has never had any charging related problems, and was showing over 13v on the gauge earlier in the day.
I'm pretty sure its the ignition switch, and here's why. The fans had stopped working at some point, and a previous owner rewired them into the fuse box (basically tapped into another fuse) to an IGN-hot source, so the fans normally run all the time with the ignition on. They're not running at all now. Also, the car has been running on for a few seconds after the key is turned off recently (which I'm thinking is probably feedback through the harness from the fans, to the ignition switch...haven't had time to get into this lately). I'm sure this needs to be fixed properly, or at least routed through a dedicated relay or fuse to power the fans and prevent this from recurring.
Any ideas? Am I on the right track here?
Old Feb 5, 2005 | 11:24 AM
Re: Ignition switch problem?
Use a meter or test light to prove whether you are getting power to the things that are powered when the ignition switch is on. All "always hot" circuits should not change.
liamcg97
Nov 25, 2019 05:55 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
robcarnut
Mar 20, 2015 03:40 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
