ignition stressing me out
Old May 22, 2015 | 10:04 PM
chevyalltheway's Avatar
Hey im new here and i decided to join because i been having an ignition problem with my 02 z28. It all started two weeks ago when i inserted the key and turned it, but the ignition switch was loose. So i had to tow it back to my house. I took the steering wheel off and fixed the problem, it was the actuator rack that wasnt in the notch. So i put it back together, but now the car doesnt crank to turn on. But the lights in dash go on and so does the stereo when i turn it on i just hear a little click. I really would apreciate for some opinions or answers.
Old May 24, 2015 | 09:21 AM
Re: ignition stressing me out
What exactly was loose - the key cylinder, the ignition switch (which is further down the steering column) or the rod that connects the two?
Does the "SECURITY" light come on?
See if this helps - it's for an earlier year, but the concepts are all the same:
Courtesy of Shoebox
4th Gen F-body Ignition Switch Replacement
Old May 24, 2015 | 04:07 PM
It was they key cylinder that was loosen. And yes the security light does stay on.
Old May 24, 2015 | 04:26 PM
Nvm it was the actual rod and the actuator
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
PopoFormula
Oct 12, 2015 04:19 PM
tommalcolm
Sep 11, 2015 03:39 PM
Aaront810
Sep 11, 2015 11:24 AM
