Idler Pulley for 1995 Camaro Z28 Lt1 with AC
Old Aug 13, 2017 | 11:44 PM
sbellis's Avatar
Does anyone know which idler pulley is proper for a 1995 Camaro Z28 with AC?
Seems there are 82mm ODs which often say without AC and then there is a 76mm version which doesn't specify. It also appears that the same pulley OD is for either V6 or V8.
The bearing appears consistant across many manufacturers as a
6203 DDU Ball Bearing 17x40x12 mm deep groove ball bearing.
Thanks,
Stephen
Old Aug 14, 2017 | 10:22 AM
Re: Idler Pulley for 1995 Camaro Z28 Lt1 with AC
With A/C there is only a tensioner pulley. Is that what you are asking about? Or are you asking about the "A/C Delete Pulley"?
Shoebox's part list indicates these part #:
1993-1997 belt tensioner 12552509
a/c delete pulley 10115875
Both part #'s are still available.
Old Aug 14, 2017 | 02:54 PM
sbellis's Avatar
I'll go with the option of not buying the part that does not go on the car then!
Just the tensioner device with the pulley for me.
Just too tired to think straight after going through all the hoses for the cooling and heating system.
Thanks for setting me straight.
Stephen
Old Dec 18, 2017 | 08:53 PM
Camaro91RS's Avatar
Do you know anywhere online that still sells the GM a/c delete pulley?
Thanks!
Old Dec 18, 2017 | 09:54 PM
https://www.summitracing.com/parts/nal-10115875
https://paceperformance.com/i-513371...ompressor.html
Buy GM 10115875 Pulley, genuine OEM part
If it truly is "discontinued", the Summit link has a link to a Dorman replacement at much lower cost.
Old Dec 18, 2017 | 11:20 PM
Camaro91RS's Avatar
Thanks Injuneer -
I was hoping to find a pulley where I didn't have to drill or use washers - but looks like I may just have to go with the Dorman
