Idle issues with starting/ Using C.A.T.S Tuning
Old Jun 17, 2021 | 12:12 PM
Cayden_245's Avatar
I purchased a 1994 Camaro Z28 that has a tune on it, now according to the program eehack (For active live Data) the program says the car starts and idles at about 650-700RPM but according to CATS tuning software the data log for Idle IN park/Neutral it says it should be 850-950 across the board. So i'm not completely sure what i should check on to see why the idle is so far out.? Or what i should do. I'm aware the TPS can be manually moved, but the computer ultimately determines Idle speed, and i'm not sure how to go about editing it on C.A.T.S. Overall, the idle in park/Neutral needs moved up only. In drive, and once it's warmed up it idles at about 950-1000RPM which is good. But only when i first start it, it does that
Thank You in advance!
Old Jun 17, 2021 | 01:05 PM
Re: Idle issues with starting/ Using C.A.T.S Tuning
In the program there's a table that sets target idle speed in neutral, and independently in drive, versus coolant temp. There's a stock table in my LT1 scanning guide.
https://www.camaroz28.com/forums/com...-guide-886891/
speedracer69
Nov 20, 2005 04:28 PM
Viking
3rd Gen / L98 Engine Tech
Aug 26, 2005 05:09 PM
Ponyhntr
Jun 18, 2004 07:14 PM
Fastbird93
Aug 14, 2003 12:06 PM
sleeperZragtop
Mar 23, 2003 08:08 PM
