ID This electrical part? 1995 Z28
Old Feb 14, 2015 | 11:48 AM
4586's Avatar
Can anyone ID this part from a 1995 Z28?
Approx 1X2"
Three wire plug in (blk, blu, gry)
Two wires out (blk/blk)
Part# Ranco 3334-06
Old Feb 14, 2015 | 12:29 PM
Re: ID This electrical part? 1995 Z28
Is it under the hood or under the dash? Appears it's patched into something in the engine or body harness bundle. What are the other plugs (blue, white, black) in that bundle for?
Black blue and gray wires are used on the TPS sensor. I had a module similar to that patched into the TPS harness, used as a WOT switch for a nitrous kit.
Old Feb 14, 2015 | 01:21 PM
4586's Avatar
It was located under then dash about one foot from the firewall grommet, the other plugs are starter wires, gauges etc. At first thought it might have something to do with VATS..but the wire colors match the TPS.
I'll try to back trace it to the ECM connectors...
Old Feb 14, 2015 | 01:40 PM
4586's Avatar
Traced them out:
GRY Black connector #B29 5volt reference
Blu Blue Connector #D24 A/C Evap Temp sensor signal
Another one I don't need
Thanks Injuneer
Garcia5
Jul 7, 2022 06:51 PM
calaban
May 18, 2020 06:43 PM
Jan 5, 2015 07:14 PM
pete53
Dec 9, 2014 07:31 AM
MJ_Z28
Aug 7, 2002 07:15 PM
