I think i twisted my frame.....
My t top never leaked when i first bought the car but after a few mods and a few trips to the track the leak pretty bad. I never put sfc's because i never thought the little mods i did would make that much of a difference but the car hooks realy well. How do i fix it?
There is no frame to twist. The entire unit body twists. A body shop could tell you if it happened.
On the other hand, I took my setup to 500HP before I added the 6-point roll bar, and integrated SFC's, and I never had a problem with the T-tops leaking. Have you checked the seals for damage?
I had the same problem. Totally leak free and all of a sudden I had a ton of water in my car. Here is how I fixed it... T-top Leak Fix
Read Posts 31 & 40
Read Posts 31 & 40
Not sure what permitex is but the plastic comes off really easy. From what I remember, you pull the big snap clip out from under the handle and then remove a couple of screws that hold the plastic down. I think the screws are on either end of the t-top. I used RV silicone as it is good in all types of weather, bonds good to glass and plastic, and can flex.
CARiD
Sep 30, 2015 05:44 AM
Catmaigne
Jul 14, 2015 05:17 PM
