How to tighten rear view mirror?
Old Sep 16, 2011 | 08:02 PM
mudbone's Avatar
Ok, i've search CZ28.com and pounded Google. My rear view mirror on my '95 is loose and vibrating. If I push down on it against the mounting tang, it will tighten up for a bit. All my other cars have had a screw to tighten that wedged the mounting flanges together. This car appear to have nothing. What gives?
Old Sep 22, 2011 | 02:27 PM
Hank'sZ28's Avatar
Re: How to tighten rear view mirror?
Mudbone,
Are you sure that there's no bolt or screw that you can tighten down in order to resolve the rear view mirror vibration issue? I seem to recall that the bolt located by the mounting bracket can be tightened down. It's depicted as ref #9 in the diagram below:
*diagram courtesy of gmpartsgiant.com
Old Sep 22, 2011 | 04:22 PM
jcl69cam's Avatar
My 95 Z doesn't have a set screw either, but it is tight. You could take it off and drill and tap it for a set screw.
Old Sep 23, 2011 | 04:22 PM
mudbone's Avatar
No setscrew that I can see is present. I tried to take it out of the car for a look-see in good light (you'll be old one day, too). I could not get the wire for the lights to release. There must be a trick to that that I can't master. I'll have a closer look tomorrow with the drop cord.
If I can ever get the damn thing off, I think the drill and tap idea is excellent. Thanks.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
timmy39120
May 2, 2015 05:12 PM
Fatdog2
Jan 24, 2015 12:08 AM
Red97LT1
Jul 28, 2002 06:37 PM
