How to remove flare nut without rounding.
Old Jan 11, 2010 | 09:09 AM
SweetZRag's Avatar
Thumbs up How to remove flare nut without rounding.
I figured out a trick for removing stuck flare nuts without damaging or rounding them. I have never damaged one since using this and thought I would pass it along.
Spray a little penetrating oil on the fitting. Place the appropriate size line wrench on the fitting. Now, clamp a pair of vice grips over the end of the line wrench. Clamp it tight. This prevents the end of the line wrench from spreading open slightly which results in damage. I also found that if I hit the wrench sharply with my hand, it usually breaks lose with less chance of damage than pulling the wrench slowly.
I hope this helps somebody out. It has save my but a few times.
Old Jan 11, 2010 | 07:09 PM
slowride94z's Avatar
I just use the vicegrips that are made like a nut and they work most every time
evenly distributing the force
Old Jan 11, 2010 | 10:02 PM
SweetZRag's Avatar
I try to use vice grips as a last resort because they dig into the soft metal. Try the trick I described. You'll be surprised how well it works.
Old Jan 12, 2010 | 06:45 PM
http://www.irwin.com/irwin/consumer/...rwinProd100328
this is what IM talking about, referred to as locking wrenches
Old Jan 13, 2010 | 07:39 AM
SweetZRag's Avatar
I saw that in a post recommended by Shoebox. I would use the vice grip if you can't get it with my trick. I have never found one I can't get off without damage using the trick I describe.
AtlasXVIII
Sep 7, 2015 03:39 PM
reww86
Aug 29, 2015 06:04 PM
War Engine
Aug 28, 2015 06:04 AM
Dams76
Aug 20, 2015 08:28 AM
4586
Jul 31, 2015 06:03 PM
