How much slack in throttle cable/spring?
Old Oct 13, 2004 | 01:03 PM
ChrisS95TA's Avatar
I was doing my LT4KM just looking around and noticed that the throttle spring in my car is all loose and not evenly lined up, how tight should this spring be? Also there is alot of play in the throttle and cruise control cables. I read about how to adjust them but how much play should there be if any? Right now it is not tight at all, actually kind of sagging. Thanks for any help.
Old Oct 14, 2004 | 01:03 PM
Z28SORR's Avatar
Re: How much slack in throttle cable/spring?
Sounds like it's broken. There should be NO play in the spring and light tension on the throttle cable.
Old Oct 14, 2004 | 02:30 PM
ChrisS95TA's Avatar
Time to order some parts I take it, some of the coils on the spring almost overlap so that must need to be replaced , got a part #?
Also there is alot of play in both the cables, hopefully something I can adjust without replacing.
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
surreybrad
Sep 29, 2015 09:00 PM
KYWes
Sep 26, 2015 08:49 AM
