How much for an assembly?
Old Aug 15, 2008 | 11:32 AM
LSWHO's Avatar
What is the general cost for assembling a block?
What do I need to supply them with also?
Say I had rods/pistons/block/crank. What else should I supply normally?
I'm new to engine assembly.
Also, if this isn't too difficult to do, once the rods and pistons are together is it something I could to in a garage? I am VERY mechanically inclined. (I'd buy an LT1 build book)
And if this isn't advanced enough, I'm sorry.
Old Aug 15, 2008 | 11:44 AM
ulakovic22's Avatar
Assembly normally cost around $250 from what I have found.
Normally you would have the machinist assemble the RA so they can check tolerances and what not to get it right. It isn't difficult to assemble an engine, you just need to have the machinist get everything where it needs to be and order you bearings. Have him install the cam bearings for you and also the pistons/rods if they are press fit, it's just easier.
Old Aug 15, 2008 | 01:11 PM
mdacton's Avatar
$1500 for a race engine. $650 for a stock one.
Old Aug 15, 2008 | 01:16 PM
ulakovic22's Avatar
Just for assembly? Does that include machining as well?
Old Aug 15, 2008 | 01:29 PM
LSWHO's Avatar
It would be mostly a street car. So nothing crazy. Just some better pistons and rods and such, probably stock crank since they can hold more power than I'll ever make.
Old Aug 26, 2008 | 10:57 AM
SSQATCH's Avatar
I just took dilevery of my new motor so I have a little insite. What I learned was to find somebody you can trust, understands your expectations and knows what your timeline is. In the end it costs what it costs and the cheapest person might be the best and the most expensive might be the worst. I'd have to say anywhere from $300-800 would be reasonable but your selection on crank/rods/pistons will also be a factor as some of the offshore pieces require more time due to variance than the more expensive options out there.
FYI,
TOM B
Z Power
Sep 19, 2015 11:19 PM
Henson071
Sep 18, 2015 04:01 PM
Str8hp
Parts Wanted
Aug 25, 2015 06:03 PM
Dams76
Aug 20, 2015 08:28 AM
Rod Bender
May 16, 2015 02:16 PM
