How hard is it to install a cat-back exaust?
Im getting my Magnaflow tomorrow and im wondering if i could do it myself. But i have a few questions:
-Does the car need to be up on a hoist to do this?
-Does the cat bolt on or weld on?
-Will there be any welding to do?
Thanks for any help
Thanks for any help
Re: How hard is it to install a cat-back exaust?
You need a jack and jack stands or a lift and basic hand tools. The hardest part will to get the stock exhaust off, you will more than likely have to cut it in 1 or 2 spots. The catback should then just bolt right up.
very very easy. Like he said, once the old exhaust is off it's cake. You will need a sawzall or cutting torch. I suppose you could do it with a hack saw but it'd be difficult.
I did mine at a Jiffy Lube, thanx to my bro-in-law, and the old was definately the PITA! Just a tip, after you bolt it on and listen to your hard work go and get it welded. Mine kept coming loose till I had it welded up. If you have a friend that has a welder and can weld have him help you out as your putting it up. Just my two cents.
Or leave it off, and just do from the cat, back (which is what is normally included in the Magnaflow 15620.)
Sawzall with 3 blades and the old one was off in 15 minutes or less.
New one bolted up within an hour, and another hour or two straightening, aligning, admiring, et cetera.
If one had done this before, and went all out at the job, I'd bet you could be done in less than 60 minutes.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
87Aerocoupe
Mar 20, 2015 01:23 AM
