How does an engine with "bent valves" act
Old Jun 24, 2009 | 01:01 AM
IRONFIST's Avatar
My car is missing slightly, its kind of intermittent, especially under acceleration.... feels like an electrical problem with the ignition.
BUT I did over rev the car and bent some pushrods, could I have damaged some valves as well?
Old Jun 24, 2009 | 06:19 AM
It might act a lot like you describe. Did you get all the bent pushrods replaced?
Old Jun 24, 2009 | 09:46 AM
IRONFIST's Avatar
Originally Posted by shoebox
I might act a lot like you describe. Did you get all the bent pushrods replaced?
Yah I did, I also over torqued a couple of the last rocker arms, I realized this when I put the car back together and it made more noise then it did with bent pushrods
Looks like somebody used one of my torque wrenches as a breaker bar for something and it's off by about 8 to 10ft/lbs. So I had to take it all apart and now it's running, no valvetrain noise, but its missing pretty good.
Old Jun 24, 2009 | 09:58 AM
Z28SORR's Avatar
Could be a bad lifter also. Need to identify which cylinder has the miss.
Old Jun 24, 2009 | 01:59 PM
IRONFIST's Avatar
How do I do that?
Old Jun 26, 2009 | 11:51 AM
Z28SORR's Avatar
Compression test.
Read the spark plugs.
Measure the exhaust temps, each cylinder.
Pull one spark plug wire at a time, see how much difference it make in the way it ildes.
Listen with a mechs. stethoscope.
Take the valve covers off and look for a short valve.
ETC. ETC.
Old Jun 26, 2009 | 06:54 PM
IRONFIST's Avatar
I bought myself a set of 243's from Davenport Motorsports... I'll be throwing those on over the weekend, that'll tell me about any bent valves.
Old Jun 26, 2009 | 10:28 PM
Maverick_997's Avatar
scan tool if check engine light.
other way to see which cylinder is "missing" is by removing injector connectors one at a time. whichever one has the least effect on the motor would be the first one to inspect.
Jeremy
BPS
9
Mar 5, 2015 10:51 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Roadie
Feb 16, 2015 10:34 AM
97z28k&N
Jan 9, 2015 04:58 AM
1996LT1Z28
Dec 1, 2014 01:01 AM
