how do I.........
Old Mar 27, 2007 | 04:39 PM
lastZ's Avatar
how do I.........
..........get the boot off the # 8 spark plug? i can get my hands in there to pull on it, but that little fuc**r will NOT come loose ....so i was just wondering if anyone on the board here has a trick , or a tool......i got the other end off the coil pack, but the other end is proving to be a bear.......i have all the other plugs done but that one!
thanks
Old Mar 27, 2007 | 06:57 PM
FNDRB58's Avatar
I assume you twisted it back and forth a few times while pulling? I don't understand how a boot can be so stuck like you say. If memory serves, I may have got to that one from underneath.
Old Mar 27, 2007 | 06:59 PM
lastZ's Avatar
yeah ive friggin tried everything......so i just left it till tomorrow.....ill give it a try again.....how did u get it from beneath....looks like even less room from the bottom?
Old Mar 27, 2007 | 07:05 PM
danhr's Avatar
got mine from the bottom
Old Mar 27, 2007 | 07:11 PM
chevynutman's Avatar
if you are replaceing plug just snap the end off then put the socket on the other part(can even use regular socket after you break it)
Old Mar 27, 2007 | 07:13 PM
lastZ's Avatar
nope not too worried about the plug....i cant get the wire boot off
Old Mar 28, 2007 | 11:20 AM
smithtim's Avatar
sometimes a pair of bent pliers will help if you can get them to fit in there...just be careful not to damage the boot by using the pliers to forcefull
Old Mar 28, 2007 | 02:21 PM
MARKTHOMASBRAND's Avatar
Jegs actually sells a tool for pulling plug wires without damaging them,might be a useful tool to have for the future.
Old Mar 28, 2007 | 02:40 PM
Z28SORR's Avatar
Don't think you understand. If your changing plugs you can break the porcelain end and free the wire from the head. You can then get the broken end out of the wire boot much easier.
Old Mar 28, 2007 | 03:57 PM
lastZ's Avatar
aaaaaaaaaaaaah i got ya!!!!!! z28sorr
