How to delete Air Pump?
Old Mar 17, 2005 | 05:52 PM
1quikZ's Avatar
Question How to delete Air Pump?
Can someone tell me how, if its possible, to delete the air pump system, I really never wanted to use it anyway but didnt have the patience to remove it before. Do you have to get the computer done so it wont throw code. What +/- are there to getting rid of it?
Old Mar 17, 2005 | 07:08 PM
V8 Slayer's Avatar
Re: How to delete Air Pump?
I know you might need a Smog Pump Delete Pulley from GMPartsDirect.com
Other than that,I dont know much about it but would also like to know.What to do with the vacumm lines that go in to the manifold after you take it out?
Is cat still needed? (More power potential there)
Old Mar 17, 2005 | 07:15 PM
Birdman7389's Avatar
naw, our air pump's are electric.
There will just be the hose that comes from your air intake (pre-maf), and the one that runs into the exhaust manifolds.
Old Mar 17, 2005 | 07:17 PM
1quikZ's Avatar
read sig.
I have no idea what to do with the vacuum lines or anything else to get rid of it, thats the info im trying to get a hold of.
If anyone has done it or knows how id appreciate their imput
Old Mar 17, 2005 | 07:19 PM
1quikZ's Avatar
ha, should have waited 5 more minutes, so everything is electric then, what about the computer?
Old Mar 17, 2005 | 07:20 PM
V8 Slayer's Avatar
Wait a second,what do you mean everything is "electric"?
Old Mar 17, 2005 | 07:22 PM
Originally Posted by 1quikZ
read sig.
You can get the plugs to block off the bungs on your longtubes, or have them welded closed. Plug or block the one in the CAI. I'm not sure if it will throw a code or not, but I think it will.
Old Mar 17, 2005 | 07:28 PM
1quikZ's Avatar
awesome, so other than that i can pull that ******* thing off?
Old Mar 17, 2005 | 08:27 PM
n2oblkz
Guest
Posts: n/a
Yep, I just pulled mine off, removed all of the lines including the aluminum tube and trashed it. It really cleans things up.
Old Mar 17, 2005 | 08:32 PM
1quikZ's Avatar
thanks a bunch man, no prob with ecm?
Old Mar 17, 2005 | 08:54 PM
NOS2006's Avatar
Mechanics for Dummies: What's the point of the Air Pump?
Old Mar 17, 2005 | 09:13 PM
Rashiki's Avatar
I believe it is to put some oxygen into the exiting fumes to make the cats work better, lessening emissions.
It's 7lbs straight off the front of your car too when you take it off
Old Mar 17, 2005 | 09:28 PM
In the 93-95 codes, you can simply pull the plug off the AIR pump, and as long as there is a good fuse in the circuit, you will not get a code or an SES light. In the 96/97's you have to have the entire system "programmed out" to avoid an SES light.
The AIR pump in the 93 and up models is run by an electric motor, not by a belt. So, you don't need a "smog pump delete pulley."
On the LT1 cars, it only runs for a few minutes at startup to help warm the cats up to operating temperature faster.
awesome, so other than that i can pull that ******** thing off?
Do the moderators a favor, and do not test the language filter.
Old Mar 18, 2005 | 08:27 AM
hotrodmama's Avatar
would a bad air pump cause ticking?
Old Mar 18, 2005 | 10:27 AM
1SlowFormula's Avatar
It has been known to happen!
Also for the original poster here is a writeup for doing this!
