How can I check the codes
without buying a code tool? ($30 paper clip) My durango will flash the codes if I turn the key on and off in a certain sequence. How about f-bodies? I might finally buy one tomorrow, and I'd like to be able to check so I don't end up buying someone elses problem. Thanks.
Re: How can I check the codes
What year is your car?
For the 4th gens: If its a 93, you can use the paper clip trick. 94+ you need a scan tool. On thing to do if you need to know a code, and don't want to buy a scanner. Autozone will scan your car for free around here, see if they'll do it where you're at too.
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
What year did these cars go to obd2?
