Horn slip-ring replacement
Old Aug 15, 2014 | 12:36 PM
Z4Ccoupe's Avatar
I have had this apart before but it has been many years ago and I guess old age is creeping up on me, but...
I need to replace the horn slip ring in my 96 SS. I have the snap ring for the air bag trigger/sensor/whatever out but I can't get the sensor out. I don't want to pry on it. That doesn't seem like a great idea but it doesn't want to move. What am I forgetting? Thanks.
Old Aug 15, 2014 | 02:53 PM
Re: Horn slip-ring replacement
That's the SIR coil, or "clock spring" that allows the wires to be routed through to the steering wheel, while still allowing the wheel to rotate. Did you unplug the SIR coil harness connector at the base of the steering column. That may be preventing the coil from moving.
Before doing anything lock the steering wheel straight ahead, remove the "AIR BAG" fuse and let it sit for 10 minutes.
Old Aug 15, 2014 | 04:14 PM
Z4Ccoupe's Avatar
I'll check that connection. I thought I had pulled the one on this car before without disconnecting anything at the base of the column. I disconnected the battery before I started working on the car. Does that work instead of pulling the "Air Bag" fuse?
Old Aug 15, 2014 | 07:38 PM
Disconnecting the battery works.
sahlomonic
Parts Wanted
Sep 19, 2015 10:17 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
ANDYZ28
Dec 29, 2014 09:13 PM
Hurin
Dec 13, 2014 07:38 PM
fpete1992
Dec 11, 2014 03:51 PM
