Highbeam switch broken?
Old Nov 14, 2006 | 11:13 AM
jjminch's Avatar
I cannot get my highbeams to turn on. There is no "click" when I pull back on the lever. I bought another stalk off a forum member who also had a steering column laying around. The new stalk did not fix the problem. On the spare column we saw a rod assembly that goes from the stalk down to this white box on the column. Apparentyl this is what turns on the headlights and makes the little "click". Can someone give me a pn for this and is there a how-to floating around on how to fix it?
Old Nov 14, 2006 | 12:59 PM
n2ceptor's Avatar
Is it for the '96 Z???????? If so, you can pick up a dimmer switch for 10 dollars at a locla parts store.... Mounts on column...
Old Nov 14, 2006 | 03:39 PM
jjminch's Avatar
Yeah its for the z, is this just a generic gm part?
Old Nov 14, 2006 | 03:59 PM
You can find reference to the switch in my ignition switch R&R on my Tech Page. Might just be loose.
Old Nov 15, 2006 | 10:36 AM
jjminch's Avatar
Thanks shoebox. So the part I need to fix is called the "dimmer switch" that's located on the column? Have a pn for it? Do I have to take the entire column out or would I be able to lower it and replace it in the car?
As far as it being loose are you referring to the bolts that are holding it in? When we were examining the spare column if we pressed down on the cables and area just forward of the stalk, the switch would work. When we did this to mine, it wouldn't.
Old Nov 18, 2006 | 02:32 AM
jjminch's Avatar
ttt
Old Nov 18, 2006 | 08:02 AM
Dave89IROC's Avatar
yes, themounting holes are slotted(for adjustment(), so loose screws will make it not work
you need to lower the column to get to it
IndyZman
Oct 22, 2015 02:17 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
mmf_1013
Sep 12, 2015 08:56 PM
Toxintwins
Sep 11, 2015 11:13 AM
jackpawt883
Sep 10, 2015 08:53 PM
