High pressure in A/C low side line?
i bought an r134a recharge kit and I was testing the pressure before adding any refrigerant and the guage read 150 psi, way over what it should be reading. What does this mean and how do I release the pressure?
The a/c is not cool at all, on the highest settings it just blows warm air out.
r u sure u have the valves open when the guage lines connect to the A/C lines? if u did have them open and had that pressure,the orfice (sp?) could be clogged i think.
when was the last time the A/C did work?
if you have not added any freon since the system was working and it is reading 150 psi then there is a problem. The system will not operate at that high of a pressure. Like rice killer said, the orfice tube could be clogged, if it is and you keep running the ac the comprssor will probably burn out as well because after a while it is not going to be getting any oil. you may need to have someone who knows take a peek at it, a/c can be tricky sometimes.
Jan 23, 2015 01:13 PM
