hey guys, first post, need some help
Old Mar 18, 2005 | 06:51 AM
locrain's Avatar
monday i am going to buy a 2000 black z28 with 95,000k. magna flow(3"), edelbrock headers, k&n air filter, hypertech prog.$ 7000. what are some problem areas i should look for? also, about how much hp and tq should i be getting? lastly, what is the hypertech prog.? thanks.
Old Mar 18, 2005 | 05:53 PM
FastrDamnit!'s Avatar
Lightbulb Re: hey guys, first post, need some help
A4 or M6?
Aside from the generic used car stuff you'd check, some things that have come up on LS1 f-bodys are warped brake rotors, burning excess oil, bad cat convertors, slow power windows (notorious on these cars!) and any potential problems with the rear axle. Generally as long as the car was treated decently you should have no problems...
Guessing your bolt-ons (cat-back, shorty headers, air filter, and HP tuner) and assuming your an M6 I'd guess you'd be at 310-315 HP.
By the way the Hypertech programming has been known to actually lower HP in some cases.
Old Mar 19, 2005 | 12:31 AM
locrain's Avatar
m6, sorry. aren't these supposed to make 305-325 stock? yeah, i plan on getting it "flashed" back to stock. how do i do that? how would i tell if the cats are bad? should i just cut them out anyways? how would i check for the oil? the only way i know is to run your finger in the pipe. thanks.
Old Mar 19, 2005 | 01:00 AM
codyss's Avatar
You can use the Hypertech to return it to stock programing. And LS1's burn oil one of two ways what goes by the rings or what gets pumped through the PCV.
As for the cats leave them in, if they are bad (usually drivers side) it will throw a code and stink.
And just a note all 98-02 LS1's are usually good for 330-350 flywheel HP.
Old Mar 19, 2005 | 07:07 AM
locrain's Avatar
yeah, but how can i tell?
Old Mar 19, 2005 | 07:08 AM
locrain's Avatar
so i can smell it? and why shouldn't i take them out? don't they hurt power?
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
Brent94Z
Mar 21, 2002 04:44 PM
