Help wiring in gauges!!
Old Jul 14, 2005 | 07:51 AM
silv3rsw33t's Avatar
Arrow Help wiring in gauges!!
I have done a search and found many replies by Injuneer on this but everything is LT1 and didn't find anything on LS1. I have the light switch pulled out and I am looking at all the wires on the switch and dimmer but what I would like to know is if I could wire my autometer lunar series gauges into the dimmer so I could dim those as well as the dash at the same time or am I stuck tapping into the brown wire on the switch? And could I also tap into either of the large red wires on the light switch as well or is there one 12V ignition source? And in the instructions it says to ground it into a good engine ground, now is this a any good ground or am I looking for something the actual engine is grounded to? Because the wire sure the hell aint long enough for that! So can someone help me with these 3 questions I would sure appreciate that!!
-Travis
Old Jul 14, 2005 | 07:45 PM
BlackDog's Avatar
Re: Help wiring in gauges!!
I don't see why you couldn't use the dimmer wire. Any ground wire in the dash or to a metal part under the dash would be fine.
Old Jul 15, 2005 | 01:12 AM
Thanks!
Old Jul 15, 2005 | 08:43 AM
The brown wire will be fine and any metal ground will too. The red wire on the switch is always hot, so you don't want that. Look in the fuse panel. There is usually a spare slot that says IGN or ACCY. That should be powered only when the ignition is on. Use a meter or test light to check it out, if you need to.
Old Jul 15, 2005 | 08:56 AM
I wired it to the HVAC fuse, is that okay?
-Travis
Old Jul 15, 2005 | 03:42 PM
BlackDog's Avatar
-Travis
That's fine.
warmeck
Mar 22, 2015 06:43 PM
mattstrike
Mar 11, 2015 07:33 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Rich_z28
Aug 29, 2002 10:44 PM
