Help - oil sensor issue
Old Feb 25, 2021 | 01:15 PM
sean9316's Avatar
I was reading all the boards and decided to put a heated O2 sensor in my 1989 Camaro IROC 5.7 TPI. While I was going to be under the car and right at the sensor anyway since when headers were installed that is the location for it decided to change the oil pressure sensor at the same time. Car ran before I switched out the sensor and now it will turn over but not start. I am going to assume that this is a sensor problem with the one I installed but now I am thinking that the fuel pump relay might be bad as well. So just curious if anyone knows if the oil pressure sensor could make the car not start and if so does that mean the fuel pump relay has been bad and running on that sensor only.
Old Feb 25, 2021 | 05:00 PM
Re: Help - oil sensor issue
See post #6 in this thread:
https://www.camaroz28.com/forums/3rd...switch-209652/
Old Feb 25, 2021 | 05:36 PM
sean9316's Avatar
OK Thanks
EviLBoX
Jun 27, 2007 08:02 AM
shortdog273
Apr 16, 2006 11:07 PM
CamaroZ28Coupe
3rd Gen / L98 Engine Tech
Jun 10, 2004 08:44 PM
96ta(nick)
Jan 24, 2004 02:21 PM
cobra2550
V6 Tech
Nov 28, 2002 10:44 PM
