LG4's have a MAP sensor?
Old Jun 9, 2004 | 01:52 PM
CamaroZ28Coupe's Avatar
is their some kind of sensor that LG4s have, like vacuum sensor or something?
what does it do
Old Jun 10, 2004 | 07:04 PM
Marc 85Z28's Avatar
Please try to phrase your questions better. If no one understands you, you'll never get an answer.
LG4's do have a vacuum sensor. Its called a Differential Pressure Sensor, and works just like a MAP sensor does. However, the readings are inversed. Do not confuse the Manifold Absolute Pressure sensor that most other cars have with the Differential Pressure sensor. Replacing a DP sensor with a MAP sensor (common mixup among parts store monkeys) will create nothing but problems. It will not set a trouble code, but will run terribly and leave you scratching your head. Even a scan tool wouldn't help here. The tool will read correctly, and the ECM isn't smart enough to realize the readings are backwards. Ask me how I know
Old Jun 10, 2004 | 08:44 PM
thanks a lot man, that must be why no one ever answers me
ill work on imy wording
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
zajones
Jul 30, 2015 02:18 PM
Noct
Jul 14, 2015 01:18 AM
