Help with drivers side window in 94 T/A
About 6 months ago my drivers side window REAR mount broke loose from its mounting arm so the window would slide back and forward when I either accelerate or stop. I figured I'd get around to it eventually. Well...last week the 14 year old power window motor finally died so I took it apart tonight to replace the motor and have a look at that rear mount. Motor...piece of cake.
Rear mount appears to be called a sash channel...its riveted to the window and the window rests on a rubber coated bar. This whole part which originally had a guide wheel has torn loose from its guide channel...and the roller wheel is sitting at the bottom of the guide. Where can I find this entire assembly which is riveted to the glass? I would prefer NEW, but will entertain using a used one if in good shape.
squarehead
Nov 21, 2014 08:02 PM
