how to remove gas tank door?
Old Jul 11, 2008 | 07:41 PM
CamaroCasanova's Avatar
I need to take it off the paint the quarter panel, is there some magic trick I am just not seeing?
Thanks!
Old Jul 11, 2008 | 08:45 PM
pcgamer4life's Avatar
Never pulled it off, but for some reason I think there are two torx or phillips screws holding the black plastic shield around the inside, and maybe there are bolts for the hinge under that?
Old Jul 11, 2008 | 11:54 PM
I think it is riveted.
Old Jul 12, 2008 | 10:20 AM
MARKTHOMASBRAND's Avatar
Just been to have a look,mine has four rivets.
Old Jul 12, 2008 | 11:19 AM
riveted is not what I wanted to hear I guess I will have to get up in there and figure it out.
Old Jul 12, 2008 | 11:20 AM
CGrant's Avatar
the gas tank door on these cars is a major PIA, you will need to drill the rivets and you can out in new rivots or srews, i just used screws.
Old Jul 12, 2008 | 06:18 PM
I drilled out the rivets with a 1/2 drill bit-it came right out. I think putting it back in with screws will be the easiest.
Old Jul 14, 2008 | 06:50 AM
MILESF's Avatar
Smile
Hi, Steve. I see your back on the board!!! Welcome back. Do you miss the convertible? If you are removing a gas door from an F-Body, you must have another one!!!!!!!!!
Fred
South Carolina
Magenta_Hearts
Mar 22, 2015 03:36 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
canbaufo
Feb 24, 2015 10:27 AM
Deadbolt24
Jan 19, 2015 01:29 PM
blac94Z
Nov 24, 2014 07:12 PM
