heater barely getting warm
Starting to get some cold days up north in Ohio and my heater has been blowing barley warm air when set on full heat. No leaks from the heater core and the blower is working fine. Any ideas or previous experience with heater issues? Any help is appreciated. I did a search and didn't find much. Thanks
Re: heater barely getting warm
Unplug your water lines that go to/from the heater core. Hookup a hose to them and flush, then flush in the opposite direction. Alternate a couple of times. Hook it all back up and (hopefully) enjoy heat once again
I'll try flushing it out as you guys have suggested. Probably just build up. My ride does have 150k on it. I'll keep you posted on the result. Thanks
Finally some heat
Guys, your all brilliant. Finally found the time to flush out the heater core. Took some serious pulling to get those 11 year old hoses loose! flushed it with my garden hose, both sides, reconnected the hoses and clamps, fired the beast back up. Within a minute I started to feel some warmth. Once the car was at normal operating temp I turned up the blower and I don't think I have felt air that hot since 1996. You guys are the bomb.
tdigger9899
Sep 7, 2015 10:56 AM
If you flush the heater core don't get the opti wet
