heater
Old Oct 27, 2005 | 02:28 PM
Notacamaro's Avatar
heater
My heater sucks. Sometimes it blows fairly warm air and other times it blows pretty cool air. It runs at normal operating temperature according to the gauge. I've already flushed the cooling system. Anyone had a similar problem?
Old Oct 27, 2005 | 02:58 PM
BigEvil's Avatar
Re: heater
Are you running a 160 degree thermostat? If so, that could cause it.
Old Oct 27, 2005 | 03:18 PM
Notacamaro's Avatar
Re: heater
I don't think so, but like I said, according to the gauge, it runs around 200 degrees or so.
Old Oct 27, 2005 | 09:34 PM
Notacamaro's Avatar
Re: heater
Anybody else have any ideas?
Old Oct 27, 2005 | 10:35 PM
Re: heater
Flush the heater core.
Old Oct 27, 2005 | 10:44 PM
95LT1Z28's Avatar
Re: heater
Shoebox is right on. The same thing happened on my Dad's '96 Impala SS. Just disconnect the two heater lines going into the firewall on the passenger side in the engine compartment. Connect a line to your garden hose in one end and use another hose to let the water drain into a bucket. Do not turn your faucet completely open, about 1/3 to 1/2 is plenty. I would imagine some chunks of **** will come out just like my Dad's car. When the **** stops flowing out, reverse the hoses to backflush any crud that may be stuck in there still. Re-connect your oringinal heater lines and top off your coolant if you lost a decent amount. Heat should be back to normal!
Jeff
BTW, make sure your heater control inside the car is all the way over to the "red" area when you flush it.
Old Oct 27, 2005 | 11:38 PM
Notacamaro's Avatar
Re: heater
Well, I had the coolant system flushed with the heater on. That worked on my s-10, I don't see why it wouldn't work on my Camaro.
Old Oct 27, 2005 | 11:47 PM
95LT1Z28's Avatar
Re: heater
Trust me on this one, you need to flush the heater core independently from your cooling system. My dad had his cooling system "flushed" and his heat worked for 2 days before it went back to the luke warm air. It will take only 20-30 mins. of your time to flush out your heater core and have heat once again.
Jeff
Old Oct 28, 2005 | 07:33 AM
Re: heater
It is probably easier if you disconnect the heater hoses at the water pump. This will flush the hoses and the core. A normal flush never seems to get the heater core cleaned out because of the flow restrictor that is in one of the heater hoses. As always, keep the water off the optispark.
Old Oct 28, 2005 | 08:24 AM
Notacamaro's Avatar
Re: heater
Ok, well I will give that a shot.
Quickss96
Jan 29, 2016 05:56 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
Jan 23, 2015 01:13 PM
pologreen97z
Dec 2, 2014 10:42 AM
