Heat/Tstat Question
Old Feb 5, 2007 | 02:43 PM
lovemyblackz28's Avatar
Heat/Tstat Question
Its been quite cold here in NY. Im driving with the girlfriend in the car and she starts complaining how the heat isnt working. The air that is blowing out of the vents isnt hot. Its sort of luke warm. Its not blowing out cold air, but its not that hot either. Would that have anything to do with the 160 tstat?
Old Feb 5, 2007 | 02:55 PM
Craddock's Avatar
You need to flush out your heater core probably. It's not hard to do when it's warm out or if you have a garage, but you'll probably just wait till it warms up if it's really cold outside.
Look it up on here.
Old Feb 5, 2007 | 03:01 PM
When the car is warmed up, the heat isnt that hot really. I can put the fan speed on the highest setting & still not hot heat, only luke warm heat
Old Feb 5, 2007 | 03:15 PM
Craddock's Avatar
Your heater core needs flushed. It's not hard, you just disconnect the two hoses that go to the heater core, wash it out through one side, then the other.
Old Feb 5, 2007 | 03:33 PM
I shall try that. Tanx!
Old Feb 5, 2007 | 03:40 PM
2000GTP's Avatar
Its pretty common for the heater cores to get gummed up and cause heating issues in these cars. Your t-stat shouldn't be the issue in this case.
Old Feb 5, 2007 | 04:25 PM
exgmguy's Avatar
a 160 thermostat will result in cooler heat, but enough to keep warm. My car has a 160 a warms up nicely enough.
Old Feb 5, 2007 | 04:32 PM
sandman63's Avatar
Okay i had great heat in my Z before i swapped the thermo.. now on cold days.. which was before i put the car away i could barely get any heat out of the thing.. by guess is that is the thermo doing it.
Old Feb 6, 2007 | 10:10 AM
OBE1 95Z28's Avatar
Turning up the fan speed is only going to make the air cooler, the air doesn't have as much time to transfer heat from the heater core.
Old Feb 6, 2007 | 10:22 AM
Thats what I was thinking. Wasnt sure. I do appreciate all the input guys!!
Old Feb 6, 2007 | 02:57 PM
sandman63's Avatar
Yeah but if the fan speed is faster.. more air.. cooler coolant temp.. less heat. I highly doubt thats it. but still.
Old Feb 6, 2007 | 08:57 PM
co93z28's Avatar
LIven in Chicago and its been 10 below not including the windchill. Just brought my 93 z in for the heat and he flushed the heater core out 3 times and traced it backwards, it turns out a piece of silcone or plastic was stuck in one of the lines. Now nice and cozy!!!!!
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
