Headlight switch
Old Aug 16, 2016 | 10:57 AM
Bxlt1's Avatar
Headlight switch
Hello everyone I'm replacing the switch old one is worn where the thumb wheel is and I want to know is the a diagram or steps to replace it.dont want to crack the dash or any parts around it. Thank you
Old Aug 16, 2016 | 11:35 AM
Re: Headlight switch
Here is a link to the 1996 factory service manual, free download. Remove/replace headlight/dimmer switch is covered in Volume 1, Part 2, page 8C-25. Not sure if this will help. But there is a diagram showing how the switch is mounted in the instrument panel bezel. There is also a useful caution indicating not to put pressure on the switch **** or dimmer thumbwheel, or it may damage the switch.
LINK: 4TH GEN SERVICE MANUALS - Firebird Nation
Old Aug 16, 2016 | 01:06 PM
Bxlt1's Avatar
Just downloaded,damn has everything thank you. There wasn't too much on exactly how to get at I'll get it tho. I was just worried bout cracking or breaking the cheap *** plastic lol being 20 years old don't help either.
Old Aug 16, 2016 | 04:33 PM
If you have to pull the bezel (surround) off the cluster area, be VERY careful. There are spring clips that push into the main dash structure, and the plastic the clips are mounted to will break right off the bezel. I lost one of mine when the car was still relatively new.... now that they're 20+ years old, they have got to be seriously fragile.
Old Aug 17, 2016 | 06:44 AM
GaryDoug's Avatar
Prominent Member
It appears in the manual that the bezel for a Camaro has screws holding it to the IP carrier instead of clips, like in the Firebird. To remove it all the way, you may need to drop the steering column an inch or two, just two bolts under it.
Old Aug 17, 2016 | 06:55 AM
Bxlt1's Avatar
Thank you I knew this was gonna be tricky
gd1996ss
Mar 7, 2016 09:30 PM
Greg88
Sep 20, 2015 07:14 PM
97QuasarBlue3.8
Sep 15, 2002 06:56 PM
Jibberish18
Apr 17, 2002 04:28 AM
