Headers Chrome Vs Ceramic
Old 08-26-2004, 02:23 PM
Evilfrog's Avatar
http://www.tbyrnemotorsports.com/lt1catalog.html
Looking at the BBKs here. Is it worth paying more for the Ceramic?
Evilfrog is offline
Old 08-26-2004, 02:29 PM
87DJP2001's Avatar
Re: Headers Chrome Vs Ceramic
Chrome is going to look nice as long you don't start or drive the car (heat will destroy the chrome). Your other choice is all right but expensive. Look for stainless steel headers (SLP) so they will not rust. Also who can see the headers anyways.
87DJP2001 is offline
Old 08-26-2004, 03:32 PM
Mindgame's Avatar
The chrome will eventually rust, where as stainless steel will "blue". I would go with ceramic coating cause it keeps the heat in the header and out of the engine bay. Stainless is no so good in this regard.
-Mindgame
Mindgame is offline
Old 08-26-2004, 03:40 PM
TransAmGT94's Avatar
I went with chrome and regret it they turned every color under the sun when i drove it for like 3 miles
TransAmGT94 is offline
Old 08-26-2004, 06:03 PM
Advantages of cera-metallic coatings:
-reduces rust. Headers rust from the extreme heat, not from moisture. The cera-metallic coating keeps the heat inside the tube and reduces the external tube metal temperature.
-the lower tube metal temperature reduces stress and vibration induced cracking.
-the lower tube metal temperature puts less heat into the engine compartment.
-keeping the heat inside the tube keeps the exhaust gasses hotter, and increases gas velocity, increasing "scavenging".... improved intake charge due to exhaust flow inertia. Jet Hot claims 3% HP increase.
-look good
While stainless will reduce corrosion, it won't provide the other benefits. "Chrome" does nothing at all.
Injuneer is online now
Old 08-27-2004, 11:08 AM
Ucantcme57's Avatar
http://www.jet-hot.com/pages/hooker.htm
Ucantcme57 is offline
carguy0119
04-11-2016 11:11 PM
shroyvin56
04-19-2015 09:40 PM
WildRidez
03-27-2015 08:22 AM
BandDirector Blk98ZM6
02-20-2015 07:42 AM
Quick Reply: Headers Chrome Vs Ceramic
