Headers Chrome Vs Ceramic
http://www.tbyrnemotorsports.com/lt1catalog.html
Looking at the BBKs here. Is it worth paying more for the Ceramic?
Re: Headers Chrome Vs Ceramic
Chrome is going to look nice as long you don't start or drive the car (heat will destroy the chrome). Your other choice is all right but expensive. Look for stainless steel headers (SLP) so they will not rust. Also who can see the headers anyways.
The chrome will eventually rust, where as stainless steel will "blue". I would go with ceramic coating cause it keeps the heat in the header and out of the engine bay. Stainless is no so good in this regard.
-Mindgame
-Mindgame
Advantages of cera-metallic coatings:
-reduces rust. Headers rust from the extreme heat, not from moisture. The cera-metallic coating keeps the heat inside the tube and reduces the external tube metal temperature.
-the lower tube metal temperature reduces stress and vibration induced cracking.
-the lower tube metal temperature puts less heat into the engine compartment.
-keeping the heat inside the tube keeps the exhaust gasses hotter, and increases gas velocity, increasing "scavenging".... improved intake charge due to exhaust flow inertia. Jet Hot claims 3% HP increase.
-look good
While stainless will reduce corrosion, it won't provide the other benefits. "Chrome" does nothing at all.
-look good
carguyshu
01-22-2017 11:19 AM
carguy0119
04-11-2016 11:11 PM
BandDirector Blk98ZM6
02-20-2015 07:42 AM
