Header Piece Bent
Old Nov 14, 2005 | 06:28 PM
MarcR94v6's Avatar
Header Piece Bent
Will this be a problem? I didn't drop it, and it was in the box pretty tight, so I don't see how it could have happened during shipping either.
Pics:
Can it be hammered or bent back? Or will that make it worse? I'm afraid it will cause a leak.
Old Nov 14, 2005 | 08:59 PM
crasher88's Avatar
Re: Header Piece Bent
it more than likely will cause a leak. Those ball and socket style exhaust connections are pretty common for not sealing properly.
Old Nov 14, 2005 | 09:20 PM
sabre81's Avatar
you can probably pound that out
Old Nov 14, 2005 | 10:03 PM
99blackSS's Avatar
I'd try to hammer it a little. Should be fine, looks like it's just the very outer lip. If it's like the ball joints on MACs, that piece slips into the other joint. It'd be a bigger problem if that was the female end.
Old Nov 15, 2005 | 05:44 PM
MarcR94v6's Avatar
Thanks guys. Look like the bend is above the hookup, so hopefully I should be good.
bowtieboy95
Jul 1, 2015 06:49 AM
Apr 16, 2015 09:57 AM
Ken Cemo
Mar 31, 2015 08:50 AM
Dec 4, 2014 11:56 AM
