head gasket
Old 12-10-2009, 08:55 PM
CAMBURT's Avatar
Question head gasket
if one side has a bad head gasket should the otherside be replaced to if it is ok. also how are those head gasket sealers they advertise like steel seal do they actually work? any opinions would be appreciated.
thanks
camburt
CAMBURT is offline
Old 12-11-2009, 08:33 AM
RUDEDOG's Avatar
You can just replace the bad one if the other side is ok. You don't need any sealer on the gasket. Make sure you use thread sealer on the bolts and high temp rtv on the front and rear sides of the intake.
RUDEDOG is offline
Old 12-11-2009, 08:57 AM
CAMBURT's Avatar
thanks
do you think that head gasket sealer called "steel seal or themagasket" works. you poor it into the radiator and it supposed to seal leaking head gaskets.
CAMBURT is offline
Old 12-11-2009, 08:00 PM
RUDEDOG's Avatar
Sometimes it works but instead of mucking up your cooling system with mechanic in a can solutions, you should fix it right.
RUDEDOG is offline
Old 12-12-2009, 05:08 AM
gcouse7's Avatar
head gasket
If you have gone through all that trouble of pulling one head, you are 3/4 of the way to getting the other one off also. Replace both and be done with it. They were both installed at the same time from the factory, now one is bad, how long before the other gives out? As far as quick fixes, It is hard enough to keep the cooling systems operating properly without any gunk added to them. Good luck.
gcouse7 is offline
10-31-2016 11:09 AM
HectorM52
Parts Wanted
01-10-2015 09:01 PM
Jazsun
12-29-2014 12:14 PM
thenewkid
11-27-2014 09:41 AM
Quick Reply: head gasket
