head gasket
Subscribe
Dec 10, 2009 | 08:55 PM
if one side has a bad head gasket should the otherside be replaced to if it is ok. also how are those head gasket sealers they advertise like steel seal do they actually work? any opinions would be appreciated.
thanks
camburt
Reply
Dec 11, 2009 | 08:33 AM
You can just replace the bad one if the other side is ok. You don't need any sealer on the gasket. Make sure you use thread sealer on the bolts and high temp rtv on the front and rear sides of the intake.
Reply
Dec 11, 2009 | 08:57 AM
thanks
do you think that head gasket sealer called "steel seal or themagasket" works. you poor it into the radiator and it supposed to seal leaking head gaskets.
Reply
Dec 11, 2009 | 08:00 PM
Sometimes it works but instead of mucking up your cooling system with mechanic in a can solutions, you should fix it right.
Reply
Dec 12, 2009 | 05:08 AM
head gasket
If you have gone through all that trouble of pulling one head, you are 3/4 of the way to getting the other one off also. Replace both and be done with it. They were both installed at the same time from the factory, now one is bad, how long before the other gives out? As far as quick fixes, It is hard enough to keep the cooling systems operating properly without any gunk added to them. Good luck.
Reply
Subscribe
