Gauges sporadic, thoughts?
Old Apr 16, 2010 | 08:19 PM
CharlzO's Avatar
Just figured that while I was slowly cursing my other luck in life, I would toss this issue to the masses, and see what thoughts I can get on it.
I have a 93 Z-28, A4, low 100k miles. The current situation of the dash guages, are as follows:
Temperature gauge is not working at all. I did notice the sensor under the exhaust manifold connecter was broken, so it's friction-fitting at the moment. Possibly a bad sensor to that, I figured. The connection IS tight, but no movement on the guage, regardless of run time. If not the sensor, I don't know what else I should be suspecting.
The Tachometer seems to be REALLY jumpy, at least in Park/Neutral. If I rev the engine up, it revs fine, but the guage starts jumping all over once it hits about 2500 RPM. Drops down, jumps back up, never really goes above 3k on the guage. This only seems to happen in neutral/park. When in drive, it seems to operate perfectly fine. Car runs fine as well, not skipping or hesitating, regardless of the tach jumping.
Other guages (Oil, Volts, Gas, etc) seem fine.
I do see an MSD coil in the car from the previous owner. However, I haven't had a chance to figure out the wiring setup for the LT1, so I have no clue what all the check for tach input, if it's at the box, the ECM, etc. Obviously still looking through other posts and sites and things, but if anyone can either point me to one directly, or just shout out here and lemme know where to look and what at, that would be awesome.
The only other thing I can think of, is perhaps the cluster is just...dying? I dunno, not something I've had happen very often. I guess in theory I could get an aftermarket tach from my step-bro and hook it up temporarily and see if I have the same issues. I dunno.
Thoughts?
Old Apr 17, 2010 | 06:17 AM
The 93 tach is different from all other years. It is driven off the coil, via a "filter". All the other years take the tach signal from the PCM.
Key on, check the voltage on the single wire that attached to the temp sensor in the head. Measure the voltage from the harness pin to the head. You're looking for 12V. If you have voltage, and holding the broken connector firm on the sensor, the gauge doesn't move, its probably the sensor. Shoebox has a procedure for checking the sensor:
http://shbox.com/1/4th_gen_tech2.html#ect
One final check - make sure the ground strap from the bolt that holds the IC module/coil bracket to the chassis is in good condition.
Old Apr 18, 2010 | 11:20 AM
TheGreatDane's Avatar
CharlzO, I've had a similar problem with sporadic gauges (see https://www.camaroz28.com/forums/sho...d.php?t=745866). Nothing seems to be wrong mechanically, as I've already replaced the associated sensors. I'm gonna try a new approach today.
A few weeks back I had the dash apart, and noticed the electrical connection to gauges was absolutely soaked in old dielectric grease. It was from pin to pin - all over the place. That's when I thought... Maybe if I clean this crap up, my gauge gremlins will go away... So yeah, worth a try anyway. Shoulda cleaned it up back then.
Let me know if you try it, and if your tach goes back to normal.
Old Apr 18, 2010 | 11:50 PM
CharlzO's Avatar
Sounds like a plan to check. Should be toying with it again Tuesday, so I'll grab the meter and do some poking around, see what I can find out.
Thanks again
CaptainObviousI
29
Apr 29, 2021 10:35 PM
Magenta_Hearts
Mar 29, 2017 08:54 PM
maybe2fast
Mar 13, 2015 11:48 AM
99TransAmWS6
Feb 12, 2015 07:23 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
