Gauge Symbol (Meaning?)
Old Mar 13, 2007 | 04:35 PM
1994CamaroLT1's Avatar
When i started my 1994 Camaro Z28 up this morning, everything was fine. Then after it ran for a little while a light came on that was a box with looks like water in it with an arrow pointing down. It is located right near the left blinker light. I dont have a manual for my car so i was wondering if someone could help me and tell me what it meant. Thanks.
Old Mar 13, 2007 | 04:42 PM
shock6906's Avatar
Low coolant light. It could either be a bad sensor (common problem) or, obviously, low fluid. I believe if it's a bad sensor, you can just disconnect it. Do a search to make sure though. And if you do disconnect it, you'd be stay on top of that fluid level.
Old Mar 13, 2007 | 04:47 PM
reamo04's Avatar
yes, u can just disconnect it, had the same problem on my car
Old Mar 13, 2007 | 05:23 PM
MARKTHOMASBRAND's Avatar
My first reaction would be to check the weep-hole underneath your waterpump,if it's dripping out it would cause your low coolant light to illuminate.
Old Mar 13, 2007 | 05:39 PM
2001NBMZ28's Avatar
Yep, low coolant light. You can look at/download a manual at http://shbox.com/pdf/manuals.html
Old Mar 13, 2007 | 06:24 PM
2000GTP's Avatar
Before you go disconnecting stuff, I would first verify that your coolant levels are good and your coolant system overall is working properly.
Henson071
Aug 4, 2015 09:32 AM
jackpawt883
Jul 31, 2015 08:15 AM
Boss002
Jul 24, 2015 10:47 AM
Latronaxe
Jul 20, 2015 12:00 PM
Latronaxe
Jul 17, 2015 11:55 AM
