gauge problems!
Old Dec 11, 2006 | 11:01 AM
lucas49er's Avatar
gauge problems!
This weekend i started noticing that whenever i turn on my car, all the gauges jump from one end to the next, then slowly settle back to their zero position, then finally move to the correct setting (gas, speedo, tachometer). This whole process takes like 8-10 seconds, and i don't remember this ever happening before. My Tripometer also resets every time i turn on the car. If i just put the key in and turn the ignition so that i just get power but don't actually turn the car on, the correct mileage is there, but once i turn the car on, it resets. Has anyone had this problem or know what can be going on? The car was at the shop last friday getting a new water pump and muffler installed. Is there some wire that might be shorting that could cause this?
Old Dec 11, 2006 | 11:22 AM
2001NBMZ28's Avatar
What year - is it a '99? Check battery for low voltage/connections.
Old Dec 11, 2006 | 12:08 PM
I thought the odometer reset in cold weather was a common problem with the early LS1 F-Bodys, and there may have been a Tech Service Bulletin. Not sure if it was still a problem in 2001.
Old Dec 11, 2006 | 12:23 PM
2001NBMZ28's Avatar
OK, looked back at a your other posts and see it is a '99. Have the battery load tested/replaced that'll most likely fix it. If not here's the TSB number on replacing the '99 gauge cluster - 99-08-49-009 Trip Odometer Resets to Zero (Exchange/Install Instrument Cluster).
Old Dec 11, 2006 | 07:02 PM
lucas49er's Avatar
The problem just dissappeared this afternoon......think it could be what Injuneer was talking about?? It was around 25 degrees last week and this past weekend.
Old Dec 11, 2006 | 07:13 PM
2001NBMZ28's Avatar
Bet the shop left your key on and/or listened to the stereo while working and ran the battery down. If it's the battery you'll know soon.
warmeck
Mar 22, 2015 06:43 PM
mattstrike
Mar 11, 2015 07:33 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
blac94Z
Nov 24, 2014 07:12 PM
slothgrant
Aug 22, 2002 03:01 PM
