gauge night time light setup
Old Aug 16, 2005 | 07:35 PM
formula69's Avatar
ok where is the easiest/best place to wire the white wires for my a pillar gauges so that the lights turn on with my gauge cluster and headlights and such? i really dont want to run a wire ALL the way from my turn signals into my a pillar, there has to be some wire thats like right there and easy to tap into.. any suggestions?
Old Aug 16, 2005 | 08:25 PM
crazypurgatory's Avatar
Lightbulb Re: gauge night time light setup
How about the radio dimmer wire?
That sould do the trick.
Chris G.
Old Aug 16, 2005 | 11:05 PM
Why not just tap into the output of the headlight switch, or the dimmer rheostat? You wouldn't connect it to the turn signals.
Old Aug 17, 2005 | 03:40 AM
formula69's Avatar
where is the output of the headlight switch or the dimmer rheostat?
Old Aug 17, 2005 | 09:50 AM
The switch and the dimmer are on the dash. On mine it was a simple matter of pulling the bottom panel off and accessing the switches. I found an unused conector up near the headlight switch - appeared it might be factory pre-wiring for fog lights. I checked the pins of the connector with a voltmeter, and one of them had +12V when the headlight switch was on. I tapped into that wire. But you just need to access the switch or the dimmer, and probe the wires with a volt meter until you find the one that provides +12V when the headlight switch is on.
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Collector Car
Jan 5, 2015 10:58 AM
CaRParts102
Dec 6, 2014 08:45 AM
ro2207
Dec 4, 2014 06:18 PM
